Message 1 of 14
Lost 'Smart TV' functionality
Hi, we've recently signed up to BT TV Box pro, however, our TV seems to have lost it's 'Smart TV' functionality.
For some reason it can't find the wifi (wireless) network & we're struggling to establish which cables to use & where they go ?
Any advise would be appreciated.
13 REPLIES 13
Message 2 of 14
Re: Lost 'Smart TV' functionality
You will either need a cable from your TV to your router, using one of the LAN sockets, or if your TV supports it, connect via WiFi
Message 3 of 14
Hi
Thanks for your reply.
Which cable do you think we will we need please ?
ethernet/usb ? we don't have a spare ethernet socket on back of router.
TV supports wifi but for some reason can't find it ?
Message 4 of 14
@stevesim  Can you see the wifi using your mobile phone or a tablet?
Message 5 of 14
Yes, wifi working around the house, but TV won't/can't recognise it.
Message 6 of 14
@stevesim
Hi
Just to double check any possible confusion, are you saying you can't find a WiFi option in your TV settings, or you can find it but nothing happens when you try to use it?
Message 7 of 14
Hi, the TV doesn't show a wifi option to connect to.
Howevere, we've managed to connect an ethernet cable to TV & back of router & that seems to work now.
Maybe we should just disregard trying to connect by wifi ??
Message 8 of 14
@stevesim
Has the TV ever been connected to WiFi?
What make & model is it?
Our WiFi enabled TVs are both connected via an Ethernet cable.
Message 9 of 14
Yes, prior to subscribing/connecting to BT it connected to wifi.
Message 10 of 14
@stevesim
Ok, so you have a WiFi option in the TV settings network menu but that option doesn't find a WiFi signal.
