Message 1 of 3
Master socket
Hi guys - I’m sure  it’s a silly question yet…I’ve bought a flat which has a line currently not active ( it has been disconnected after the tenant left the place).   Would be possible to test if the master socket works well or do I need to wait till BT activate the line?  I will move there in a few weeks time and I want to be sure that the broadband will work since day 1…Appreciate your replies and sorry for the very “basic” question…
2 REPLIES 2
Message 2 of 3
Re: Master socket
it may be that when you take out a broadband contract you get FTTP which does not use the existing sockets or copper wire.  enter address and see what is available
Message 3 of 3
Re: Master socket
Either it 'works' or it doesn't, nothing you can do to change anything.
