Message 21 of 23
Re: Netgear Orbi Mesh + SmartHub
You need to make sure that your phone/tablet/ computer is connected to the Orbi Wi-Fi. The Wi-Fi name and password will be on a sticker on the Orbi router.
Once connected use the smart set up wizard on the Orbi app to connect to the BT FTTP using the credentials shown at the start of this thread.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 22 of 23
Hi, I’m having a similar problem here. I’ve tried the above with no luck.
Any advice?
BW,
andrew.
Message 23 of 23
@Giranimax i don’t know if you’re still having the same problem. Are you using a web browser or app when you get the error? I’d be tempted to factory reset the Orbi router (skip if you don’t want to to begin with), disconnect (forget) from the existing WiFi, connect to the Orbi WiFi, if using a browser connect to Orbi and login  as admin otherwise start the Orbi app. Go through the set up process as a router not access point. If you’re not offered the setup I’d factory reset the Orbi router. Don’t worry about the satellites they can be added later.
