Message 11 of 23
Re: Netgear Orbi Mesh + SmartHub
If it anything like the Tenda Nova mesh that I have, you need to be connected to the Wi-Fi network that is transmitted from the Netgear Orbi, and not the home hub Wi-Fi. Yo may have to "forget" the home hub SSID, so your phone only connects to the Orbi.
To manage my Tenda Nova, my phone has to be connected to the Wi-Fi transmitted from a Tenda Nova node.
Message 12 of 23
Thanks @Keith_Beddoe . I am connected to Orbi and have forget the network. Still same error though…perhaps I should change the name of the old wifi?
Message 13 of 23
Why have you still got your old wifi, you don't need the BT hub any more if you have connected the Netgear to the ONT.
Message 14 of 23
@licquorice I still have the modem/router from before. Not quite sure I’m following you though. I’m changing my BT Wi-fi to Orbi?
Message 15 of 23
Have you totally disconnected the SH2 as no longer needed?  All WiFi devices should now be connected to Orbi
Message 16 of 23
I'm certainly not following you.
The Netgear connects directly to the Openreach ONT the BT hub is no longer needed.
Describe exactly how you have connected things together.
Message 17 of 23
@licquorice ONT is connected to the Orbi router via ethernet directly. Old router (BT hub) is unplugged completely. I feel like I’m missing a simple trick here…
Message 18 of 23
Is it also unplugged from the mains, otherwise it will still be transmitting wifi even though not connected to anything.
Message 19 of 23
@licquorice yes! I’m going try and rename the old wifi see if that helps
Message 20 of 23
I don't understand what you mean by rename the old wifi, the old wifi shouldn't exist.
