Message 41 of 310
Re: New hub keeps losing wifi connections, even though blue lights lit
@imjolly
Hub is 2.2m from power supply. Yes, I used the new power cable that came with the hub. I don't think that's the problem as hub lights stay lit.
I suspect that hub, being a 'smart' hub,  is possibly constantly scanning for best broadband signal & sometimes finds a bad one - that's a wild guess though!
And I have not moved from the laptop, or switched anything else on, when it throws its tantrums.
I'll message BT again later but at the moment (while it's behaving) I can't face the thought of another (8th) long webchat!
Message 42 of 310
@WSH
The only thing in the entire house that is on a timer is the fish tank light & that comes on at 10:00 & goes off at 20:30, which is never when the hub plays up. In fact, the times the hub plays up are completely random.
I hate mysteries!!!
Message 43 of 310
@Groo
as I suggested in message 26 why don't you try moving your wifi channels from smart to fixed channels ?
Message 44 of 310
Heating thermostat?
As imjolly said, that smart channel function can be turned off and a fixed channel can be set.
Edit: And while I think about it, you've not got the hub close to a cordless phone base station have you?  Some (old type) fluorecent lights used to cause interference as well.  Unfortunately, the list of what has caused interference in the past is a pretty long one.
Message 45 of 310
@WSH
Heating thermostats only on a couple of radiators &, again, heating times don't coincide with hub tantrums.
Phone is not cordless - it's new enough to work with DV but I only have a simple landline phone as I never use it & don't need a fancy one 🙂
And no fluorescent lights anywhere in property, even the fish tank is LED.
Turning off smart channel function would be an idea, but no idea how to find a 'fixed' channel or how to set it (although presumably can set it in hub manager?).
Message 46 of 310
@imjolly
Yes, but how do I know what fixed channel & how to I even find one?
Message 47 of 310
Homepage > Advanced settings > Wireless.  Click on the wireless channel dropdown and you get a choice of the best channels to use there.  Any will do initially.  May need a bit of trial and error to get the best.
Not near the kitchen, is it?  Microwave ovens cause all sorts of problems.
Message 48 of 310
Sorry, forgot the obvious.
Type 192.168.1.254 into the address bar of a browser.  You’ll need the admin password off the card on the back of the hub to make any changes.  (That’s the Admin password, not the Wi-Fi password).
Only needs changing on the hub.  Your devices will automatically switch to the new channel.
Message 49 of 310
@WSH
No, long way from kitchen. I'll give that a try. Appreciate your help & sorry for being a non-tech person!
Message 50 of 310
@WSH
Yes, got that page saved in my bookmarks.
