Message 11 of 15
Re: Odd MAC Addresses (with no ip addresses) in 'My Network' 'log'
I started this thread on 16 Jan 2022 and around about 18th, I had had sufficient replies to 'solve the issue'.
More recently, 29th June, the thread was 're-awoken' by a new contribution, followed by 3/4 other replies  (informed by email) but when I try to view the responses via the link on each email I get:
"You do not have sufficient privileges for this resource or its parent to perform this action".
Anyone know why? I would dearly like to see the responses to my own thread !!
Regards to all.
Message 12 of 15
@steviebobs1
It was because unsuitable content was posted by a forum user, and it was removed by a moderator.
Message 13 of 15
I hope the person responsible was made aware of their error in order to avoid a recurrence in case it was simply a ‘misjudgement’
Best regards to all.
S
Message 14 of 15
The moderator would normally send a private message to the user. In extreme cases, the user would be banned.
Message 15 of 15
Thanks Keith, good to know.
S
