Message 11 of 22
Re: PS5 Nat type failed
I think its a BT network issue as I've just been doing a scan with Malwarebytes, and part of the scan routine is it checks the server for updates. Only this time its acting like there is no connection.
Message 12 of 22
Hi guys,
Thanks all for raising. We're looking into this and will update you all as soon as we get any updates.
Cheers
David
Message 13 of 22
Good man David......hopefully reolved soon or I'll need to spend time with the wife.....that'll frighten her on Halloween night !
Message 14 of 22
Another one here, been on Down Detector and it seems to be a BT problem, my connection speeds down to 13 Mbps 😞
Message 15 of 22
My Ps4 has same issue. I also cant connect to www.epicgames.com but can when on 5g off wifi
Message 16 of 22
I just clicked that epic games link and it won't load for me on PC. I'm connected via ethernet.
Message 17 of 22
Message 18 of 22
yes, same here, wifi and ethernet.....but if you come off BT home broadband, ie use data from you mobile provider, it works, so all points to BT being the problem
Message 19 of 22
PlayStation Network - NAT issues
I’m suddenly having issues connecting to PlayStation Network. Testing the connection and it’s coming up with NAT Type failure.
It was working fine up until today and I didn’t change any settings on both the PlayStation and internet
Message 20 of 22
Do you have a rough ETA to fix something like this? Thanks for info
