Message 11 of 15
Re: Port Forwarding Rules
Hello
Yes PC is turned when assigning rules but wont save in Hub Manager 😞
Any ideas?
Message 12 of 15
Yes device is turned on.
However I just tried setting up the same Port Forwarding Rules for my PC (windows 10) and the the rules were saved so any any idea why I cant do the same for my sons PC (windows 11)?
Message 13 of 15
Sounds like a Windows 11 issue then.  If a Windows 10 machine works, just set it up from that.  Doesn’t matter which machine you use to edit the settings on the hub.
Message 14 of 15
I am using the BT Hub Manager to setup the rules when I select my sons PC (windows11) rules will not save bit when I select my PC (windows 10) the rules save!
Tags (1)
Message 15 of 15
Ah, right.
More likely to be the PC firewall then.  Has he tried running the game, (or whatever), to give it a chance to modify the firewall settings?
