Message 1 of 15
Port Forwarding Rules
I am trying to set up Port Forwarding rules in the hub manager 192.168.1.254. I enter all the details and click SAVE but the rule is not saving! I have tried this both on my pc and on internet on my iphone.
Even though rule says it's saved when I go back to Port Forwarding Rules tab it is blank!
I received a new Smarthub 2 last month and it was set up succesfully.  I have also restarted hub
Does anyone know why is this?
14 REPLIES 14
Message 2 of 15
Re: Port Forwarding Rules
The SH2 tends to do that when there is an error in the information entered.
Message 3 of 15
What do you mean error in information entered?
Message 4 of 15
The SH2 will validate the settings before it saves them.  If they are invalid it will abort the save.
Post what you are trying to set and someone will identify the error for you.
Message 5 of 15
So back to my original question, why are my Port Forwarding Rules not saving?
Message 6 of 15
OK, if you are trying to forward to something in your network the IP address must be in the same network…i.e. it must start with 192.168.1
Any port number below 1024 is reserved and, (I’ve never tried it but), I would be surprised if the hub would let you set a reserved port.
Message 7 of 15
Hello Stuart
The IP address for the PC I am trying to set rules for does start with 192.168.1 and then three numbers after.
I am trying to set up the below Port Forwarding Rules for Fortnite. These were supplied by Epic Games last year.
But when I enter the details and click SAVE it says "saved" but then then the firewall page in hub manager is blank!
I have always been able to set up these rules but since receiving a new smart hub 2, I am unable to do this!
TCP/UDP
80
3478
3479
5060
5062
6250
12000 – 65000
TCP
433
5222
443
Message 8 of 15
Yes, you can forward those ports.  What I meant was, you can't change what they are assigned to.  For example, it may be that 80 is needed for the HTTP interface on the hub itself and so cannot be reassigned.
Message 9 of 15
I have tried all the mentioned Port Forwarding Rules but none of them will save!
Message 10 of 15
You should be able to assign those ports as they are associated with a different IP address.
Is the device turned on and connected while you are trying to save those rules?
