Message 11 of 11
Re: Printer connection
Change the SSiD (name) and password on the "new" hub to the same as the "old" hub that you had and your printer will most likely just connect to it as will all your other devices unless you have deleted the "old" hubs connection from them in which case you will need to re connect them.
