Message 1 of 4
Re: Wifi blocking some websites & email,but on ethernet works
I have a similar issue.  I have a website, it is being blocked on the BT network but not on other networks.
[mod edit: third party link removed in line with community terms]
3 REPLIES 3
Message 2 of 4
I have moved your post to start a new thread as it is a different problem to the thread you posted on.
Have a read here
I don't have parental controls on or use BT DNS and the site works fine for me.
Message 3 of 4
Your link works fine for me. As it is an ecommerce site I have notified the moderators who may wish to remove it fron your post.
Message 4 of 4
Hi @webdesigner.
Thanks for coming to the community.
Just a friendly reminder that we advise not to share third‑party shopping or promotional links on the Community, so I've removed it, but made a note of this at our end.
We’ve tested the site over a BT connection, and it loads normally, so it doesn’t appear to be blocked unless this is being flagged by parental controls.
It’s worth checking the steps shared by @licquorice, as they may help with what you’re seeing on your side.
Debbie
