Message 11 of 18
Re: Replacement homehub 2 has not solved my locking-up problem
Good suggestion, Keith
I'm pretty sure they're not, but it's worth double-checking.
Message 12 of 18
Have you tried disconnecting the USB hard drive it could be on it's way out
Message 13 of 18
Hi.  I have had many BT boxes and sadly they all suffered from locking up.   I now have a BT pro box which has bee replaced because locking up so does new one.  It is a known issue which does not appear to be one they can resolve or not enough people responding to make it a need to find the problem Malcolm
Message 14 of 18
That's a TV Box, I thought your problem was with your Smarthub2 Router?
Anonymous
Not applicable
Message 15 of 18
@Les-Gibson
He isn't the OP. 😉
Message 16 of 18
@mwparry
You are posting on the wrong thread, you need to find the one that deals with TV boxes locking up. This is a home hub issue.
Try this thread https://community.bt.com/t5/YouView-from-BT/BT-TV-Pro-box-problems/td-p/2200158
Message 17 of 18
@Anonymouswrote:
@Les-Gibson
He isn't the OP. 😉
Message 18 of 18
Thanks Sorry got confused.  I think the words lock up or alike get me going.  Sorry for error. Malcolm
