Message 1 of 5
Lag
Had my fibre 150 for a while now with no problems until the last couple of weeks when I've had lag on Netflix and some sites, BBC News especially.  What could be wrong?
4 REPLIES 4
Message 2 of 5
Re: Lag
Make sure that BT Web Protect is turned off. It can cause problems with some sites.
Learn about BT Web Protect | BT Help
Message 3 of 5
Re: Lag
I never enabled it.
Message 4 of 5
Re: Lag
That doesn't mean it isn't enabled.
Message 5 of 5
Re: Lag
OK.  It appears not to be enabled, there is only one option showing and that is enable so I presume it is disabled.
