Message 1 of 3
Retention of settings changes
If you changes settings on a router and power it down and unplug how long are those settings retained?
Are they retained as if they were factory settings till the device is reset or after a prolonged period they are lost?
2 REPLIES 2
Message 2 of 3
Re: Retention of settings changes
They are saved until you change them or until there is a factory reset. An update may also change them depending on what the update includes.
If the hub is powered off they will be retained until/unless one of the above happens when it's powered back on.
Message 3 of 3
Thanks for the info and prompt response.
