Message 1 of 3
Good morning,
Just a quick question for you fellow people.
Was just wondering if you could have a normal 0 Ethernet port router aswell as another router with Ethernet ports in the same house.
Let me know if you have any questions, hopefully it makes sense 👍🏻👍🏻
2 REPLIES 2
Message 2 of 3
Re: Router
No idea what you mean by that.
You can only connect one router directly to line but you can daisy chain another router from the first via Ethernet either LAN to WAN to provide 2 sub networks or as a wireless access point by connecting LAN to LAN
Anonymous
Not applicable
Message 3 of 3
Re: Router
I'm afraid it doesn't make sense. I'm not aware of the existence of a "normal 0 Ethernet port router". What exactly are you looking to do?
