Hi everyone!!
Just upgraded from 300mb to 900mb and use a WiFi6 asus card, which on 300mb was topping out the connection.
Now with 900mb fiber i'm topping out the max theoretical speed of the SH2 which is around 350-400mb.
I need digital voice and fully aware I'd lose this by using my own WiFi6 router.
So...other than cable cat6 around the house is there any alternative or future plan from BT to ditch one of the older wifi protocols?
Solved! Go to Solution.
You can keep the SH2 router for digital voice and just use one or more Wifi 6 access points (and turn off wifi on the SH2).
Do you recommend any decent WiFi6 APs?
TIA
