Message 21 of 50
Re: Setting up a Smart Hub 2 as an Access Point
@Crimliar
Yes, I quite agree.  Anyone that is using a WAP 24/7 should really invest in a real one rather than a jury-rigged hub anyway.
For myself, the reason I have a second one is for DV redundancy, so it gets to play WAP in its spare time.  While everyone is fretting about phone calls in a power cut, they seem to have overlooked that if the SH2 breaks or its power unit goes pop it will take BT several days to supply a replacement.
Message 22 of 50
Hi -
Trying to access this link - seems I don't have required permissions - can anyone help with copying the content to this thread?
Message 23 of 50
Its extremely simple to set up an SH2 as a WAP, see message 3 of this thread.
Anonymous
Not applicable
Message 24 of 50
@AJC25wrote:
Hi -
As @WSH alluded to, the whole concept of repurposing a router as an access point dates back to a time when consumer products didn't really exist outside of expensive business products. Times have moved on & there are any number of residential style products available at reasonable prices. Some of which combine the convenience of a powerline link to the router.
Repurposing a router that way is a now a poor choice & choosing a SH2 an even poorer one IMO.
Message 25 of 50
Thanks rbz5416
OK, so, its time to ditch the SH2 and start again?
Do you have any recommendations for the best kit?
Our house currently has three BT mesh discs and we have a wired point for a sort of garden room that's just been installed (but has no hardware on the end of it).
tbh, I'm so confused with all the offerings out there, I don't know where to start (and I thought I was reasnably tech savvy!)
Any thoughts?
Message 26 of 50
Having dived on to this solved thread rather than starting a new one, it is not entirely clear what you are trying to achieve.
The thread is about configuring a spare SH2 as a Wireless Access Point.
Are you saying you don't already have a second SH2 to configure?
Message 27 of 50
Please can you paste the answer into the reply as some of us do not have sufficient access privileges (whatever that means) to access the post with the response in it
Anonymous
Not applicable
Message 28 of 50
Only the Mods may have access now, but there are no hidden secrets in there, Just Google "router as access point" & take your pick of the many results & YouTube videos. But I'll say it one last time, in 2023 it really is a poor choice. Even if funds are tight, consumer APs have been around long enough to pick one up used for little cash.
Message 29 of 50
Message 3 of this thread tells you everything you need to do.
Message 30 of 50
Sorry to jump on someone else's thread, but can I ask if the other ethernet ports on the access point BT hub also work, like a normal network switch would?
Is it possible to clone the SSID to match the parent network for relatively seamless roaming?
