Message 1 of 2
Setting up new TV incorrect password
Hi
I am trying to set up a TV to my internet and I am putting in the correct password and it keeps saying incorrect password. It is 100% correct. I have tried the WPS button but that is not working either. I've turned the hub off and still no luck.
1 REPLY 1
Message 2 of 2
Re: Setting up new TV incorrect password
Hi @Jennylee12345,
Thank you for posting and welcome to the Community. I'm sorry you're having difficulties connecting your TV to your BT hub.
If you haven't tried it already, I would try factory resetting your hub. You can find the steps here - How to factory reset your hub.
Thanks,
Paddy
