Message 1 of 4
Slow Full Fibre
Had full fibre 900 installed 5 days ago. Checked speed each day and despite being told no problems has failed to reach minimum 700 speed at any time. Anything between 400 to 600. Does BT monitor and take action or should I do something?
3 REPLIES 3
Message 2 of 4
Re: Slow Full Fibre
They'll tell you to connect using an ethernet cable and test then.
Message 3 of 4
Re: Slow Full Fibre
@cinnamoncottage  The guaranteed fibre speed is to your router, not to the devices you’re connected to. If you’re attempting to run speed tests to your WiFi devices using WiFi rather than using a Ethernet cable, it’s likely you will not see the 900mbps speed to many WiFi only enabled devices.
Message 4 of 4
Re: Slow Full Fibre
Hi there @cinnamoncottage
Thanks for coming back to the community.
If you have a slow connection since being connected, please try the troubleshooting in the Fix your BT Broadband connection problems page. If this continues after you've tried these steps, you can log in to your account and we'll run tests to check for any connection problems you're having and let you know what is needed.
Thanks.
Leanne.
