Message 1 of 2
Smart Hub 2 IP address
Hi
My Smart Hub 2 made a pinging noise and restarted itself. When it booted back up it had no internet connection so I tried opening the Hub Manager using a saved to 192.168.1.254 which has always worked, but now times out.
I ran a network scan and found that the Hub’s IP address had changed to 192.168.1.22. I logged successfully from the browser with this address. The point is though that I didn’t change it. My wife knows how to turn it on and off and nothing beyond that.
Does anyone have an explanation as to how this may have happened?
1 REPLY 1
Message 2 of 2
Re: Smart Hub 2 IP address
Hi @marco63, thanks for your post.
Which hub do you have?
Have you tried a factory reset of the hub? How do I reset my BT Hub to its factory settings | BT Help
The 192.168.1.254 is the ip input to access the hub manager
Have you got an internet connection at the moment.
Cheers
John
