Message 1 of 4
Smart Hub 2 USB port can't be reached from Windows 10
I've just installed a BT Smart Hub 2.  When I try to access the USB port, the attempt fails and I'm told my computer (running Windows 10) needs the obsolete SMBv1 protocol.  Microsoft states it's been superseded by SMBv2.
Does anyone know when BT plans to update the firmware on the Smart Hub 2 to include SMBv2?  If they don't intend to move to SMBv2, why not?  What's the point of a USB port that can't be accessed?
TIA,
Chris
3 REPLIES 3
Message 2 of 4
Re: Smart Hub 2 USB port can't be reached from Windows 10
You can access it, just enable smb1 in W10
https://www.tachytelic.net/2019/09/windows-10-enable-smb1/?amp
Message 3 of 4
Perfect!
Thank you @licquorice
I love this community 🙂 ❤️
Message 4 of 4
@shed53 wrote:
Perfect!
