Message 1 of 6
Smart hub2 Firmware
Newbie here.
How do I update the firmware for my Smart Hub 2 which appears to have an old version and shows "undefined" where it should show date of latest update. It has been up and running (very slowly) for 10 days.
5 REPLIES 5
Message 2 of 6
Re: Smart hub2 Firmware
You can't.
Try a full factory reset via the recessed button and then leave it connected to automatically update
Message 3 of 6
Done that - still no update 10 days later. Version is 17. .......
Message 4 of 6
That doesn't sound like Smart Hub 2 firmware, are you sure it is a SH2?
Message 5 of 6
Yep. Just around 3 years out of date. To be precise v0.17.01.12301-BT.
Message 6 of 6
Assuming you are still in contract, call customer services and request a replacement hub.
0330 1234 150
