Message 21 of 23
Re: Smarthub 2 and RDP connection
I will PM you my public IP address. I have tested the connection and it works.
You should just get a login page, that is all you need to prove it works.
Let me know how it goes.
Message 22 of 23
@Keith_Beddoe
It did work, many thanks!
I will go after my customer's IT manager...
Thanks all
Message 23 of 23
I am pleased I could help, I will now turn off the machine.
Best of luck with your IT manager.
