Message 1 of 12
Smarthub 2 - returning it to Channel 3
Our 2.4GHz channel has really only worked on Channel 3 and was last set at that on our Smarthub 2 by BT support. Regrettably I rechecked other channels but can’t get it back to Channel 3 and unfortunately support say it’s impossible to do so as it can only be 1, 6 or 11. I have screenshots showing the Advanced Settings summary as channel 3 and the Advanced Wireless setting as Channel Undefined (but it is 3!).
Surely it’s somehow possible to reset it to what it was on 3. How could getting it back to 3 be achieved? Help very welcome !
11 REPLIES 11
Message 2 of 12
Re: Smarthub 2 - returning it to Channel 3
The information you were given about the channels you can select on a Smarthub2 is correct. You can not select channel 3.
You can select channel 3 on the Smarthub1.
Message 3 of 12
Thanks @gg30340,
The crazy thing is that it was on Channel 3 until yesterday and had been set at that by support.  Could there be some ingenious and less known way that had been done? The coverage really suffers with anything else.
Message 4 of 12
Are you sure it was not the wireless mode that had been changed. There are three modes available.
See link
www.bt.com/help/broadband/what-is-the-wireless-mode-feature-on-my-bt-smart-hub-
Message 5 of 12
Thanks for that and your interest. I’m sure it’s the channel that was 3. The mode was 1.
 Hopefully this screenshot shows what it was.
It’s quite bonkers !
Message 6 of 12
And this shows the selection as ‘Channel undefined’ although from the previous shots you can see it’s actually set at 3!
Message 7 of 12
@PRJ  Interesting. What Firmware is you Hub running?
Message 8 of 12
Thanks @Dippu, I’m assuming it was up to date. Unfortunately I’ve just swapped over the router with a new one I’d been waiting to return. Useful to refresh network and security. Probably no surprise - it’s just doing the same as the old one !
I’m thinking the oddity remains that Channel 3 is still somehow doable ?
If it really helps I could reconnect the older hub.  All help very very welcome.
Paul
Message 9 of 12
I suspect that the clue is in your first post where you stated "Our 2.4GHz channel has really only worked on Channel 3 and was last set at that on our Smarthub 2 by BT support."
As you no doubt have discovered by now, Channel 3 is not an option for the customer.
My guess then is that BT support somehow set it to channel 3 and a firmware update caused that to be reset. Another possibility would be a factory reset, that would almost certainly cause that setting to revert to the standard Smart, 1, 6 or 11
Message 10 of 12
Thanks @Les-Gibson   Yep, BT Support set it a while back as I wasn’t able to do so. Unfortunately despite great efforts by BT  Support they didn’t have the ability to set that yesterday. Since it was previously doable I’m hoping there is some special, perhaps not widely known way they could still fix it to Channel 3. That would make a big big difference.
