Message 11 of 12
Re: Smarthub 2 - returning it to Channel 3
Failing that, do you have any old kit from previous ISP's? if so you could turn the hub 2.4 off and use your old kit, set to channel 3, as a wireless access point. One benefit of that would be that you would then have separate 2.4 and 5GHz networks instead of the combined network which often causes problems
Message 12 of 12
Cheers @Les-Gibson   The only old kit is a Smarthub2 so I doubt that could be fixed in 3. I’ve also got a tplink extender which I’ll have a try with. Thanks for your help too.
