Message 21 of 50
Re: So....throttling...
Thought I'd give an update...
Second engineer visit - unable to fix but could quite easily see that full speeds are available to me, but when it comes to Seafile, only if I use a VPN. Engineer couldn't explain. Next visit is from someone in Openreach. Next week...
A neighbour, ten doors down from me (we live in a long cul-de-sac), allowed me to test his BT wifi. He has the 900 package, whereas I have the 500.
Testing now on a laptop...and at home I am experiencing exactly the same issues as I did on two desktops and my phone. Turn on VPN and laptop download speed from server is back to max. So...all the same.
At my neighbour's house, without the VPN, I was seeing 50MB/s (average) and with the VPN switched on around 90MB/s.
So what is going on here?
Message 22 of 50
See message 15.
Do a tracert to the server via both methods of connection and compare.
Message 23 of 50
Thanks. Did look at that a few days ago, but got a little bit lost.
Message 24 of 50
Maybe lack of knowledge but I'm struggling to run a tracert using VPN or not.
I have the IP address (and "logged in" on the website version so I know it's working) but tracerts just show "non-existent domain" or DNS request timed out.
Message 25 of 50
Update on my situation...
Had an Openreach engineer come out - my third engineer. Couldn't find any issue either.
Took my laptop to a neighbour, a few doors down... He's on BT 900Mbps. Didn't experience any issue with downloading from the server, with and without VPN switched on.
So "throttling" only happens at my house, with a second router, and three engineers saying the connection is fine.
Message 26 of 50
How is your device connecting to your hub, by WI-fi or Ethernet?
If by Wi-fi, have you checked that the 'Wireless Mode' setting in your hubs advanced wireless settings is set to Mode 1
If it does it on both Ethernet and wireless, have you checked that the 'Full Fibre (FTTP) Mode' softswitch (advanced Broadband Settings) is set to ON
Message 27 of 50
Tried both wifi and wired.
Will check that softswitch now... Thanks.
Message 28 of 50
Yeah...it's ON.
Message 29 of 50
What is your upload speed, as a poor upload speed will affect the download speed, as received packets will not be acknowledged quick enough?
Message 30 of 50
Not uploading anything at all.
