Message 11 of 13
Re: Struggling connecting BT pro box to EE Mini Hub
Well that might change as there is supposed to be an internet connected freeview service that is coming out next year!
Freely it is called. Initially it will only be available on Smart TVs but hopefully they will fetch it out on boxes too. It will be able to work on any internet connection, so you won't need to pay extra for a TV service.
Freeview’s Streaming Future: ‘Freely’ Unveils TV Lineup | Cord Busters
Message 12 of 13
The router for the new house has arrived.
Just a thought, is it possible for the SH20A router to use the 4g mini hub to connect to the broadband?
Anonymous
Not applicable
Message 13 of 13
The issue is that BT/EE TV via a Youview box is delivered by multicast & that can only be provided over a BT/EE broadband connection. Mobile devices can't provide that.
Your subscription is also unique to your connection, so can't be watched anywhere else, even on another BT/EE connection.
As already mentioned, this doesn't apply to streaming apps.
There is no way to use the mini hub with the Smart Hub 2.
