Message 11 of 20
Re: TP-Link WIFi Extender - no internet
Thank you.
Neither of us are gamers or heavy data traffic users, but spending a fair amount of time in a place where high speed is just that, one sort of gets used to it.
If all else fails Monday, we'll consider other options.
Message 12 of 20
I never had much success with powerline adapters or Wifi extenders.
So I went for a mesh system, with one unit plugged into my SH2 via ethernet and the other 3 units forming a mesh via WiFi. All the units have ethernet ports on them, so I can connect stuff that doesn't have WiFi to these units be ethernet cable. There is of course some speed degadation but this system works excellently. And I have one WiFi network throughout the house with stuff connected to it connecting seamlessly from unit to unit as I move around the house.
MUCH better than powerline adapters and WiFi extenders
Message 13 of 20
Indeed, a large MESH took care of my house for 4 years, then over time connected ethernet to each one but with MESH of course that didnt need to be done all at once, if you want to of course.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 14 of 20
Horses for courses, I have 3 powerline adapters that give good coverage of my largish bungalow. But then I only get about 50M on FTTC so speed isn't an issue.
Message 15 of 20
A chunk of my irk is it all worked perfectly, the Full Fibre arrived and our promised speed was patchy in terms of sometimes great, and others pretty slow, the the Powerline adapters failed - 2 of 4 failed.
Anyway, Monday will soon roll around, then we can make better informed decisions.
Message 16 of 20
Did you get it all resolved yesterday?
Message 17 of 20
Sort of/Maybe/Maybe not*  (Delete as appropriate)
We have the new router in and working.  2 new Powerline adapters in and working, but the third overlooked and dismissed as not required by the engineer.
Engineer was an "interesting" character.  Despite the promises of BT/EE, said engineer did not check our connections at the "box by the manhole", or up the pole serving us.  She only did work indoors.
We'll see how we go on this arrangement, and if necessary think again.
Message 18 of 20
Is this the engineer you get through Halo?
Message 19 of 20
To my knowledge, we don't have Halo.
It was all arranged via the standard phone-in helpdesk, after literally hours on the phone.
Message 20 of 20
Oh right, nice well at least they sent someone helpful.
Best of luck.
