Message 11 of 22
Re: Technical help
Thanks for advice.
Message 12 of 22
Re: Technical help
Copper ADSL, FTTC (Fibre to the cabinet)
Message 13 of 22
Re: Technical help
Also, put a sign on your door saying, SORRY NO INTERNETS.
Message 14 of 22
Re: Technical help
Its not copper ADSL as the copper only carries the phone connection. You have FTTC (VDSL), and there are plenty of VDSL modem/routers that will work on FTTC, it all depends on what your connection speed is.
Message 15 of 22
Re: Technical help
If you are using a BT HomeHub, you have to login to it to change the SSID. I also recommend that you disable Smart Setup in the Router, as that can be used to identify that you're using a BT HomeHub.
Message 16 of 22
Re: Technical help
That isn't entirely true, as with FTTC VDSL the D-side is still copper (or aluminium) cable.
Message 17 of 22
Re: Technical help
Thanks. Yes..Good idea.😊
Message 18 of 22
Re: Technical help
Ok.
Message 19 of 22
Re: Technical help
Ok thanks.
Message 20 of 22
Re: Technical help
Just tell anybody who asks that the charge is £50 per minute with a minimum fee of five minutes paid in advance although I would personally use a stronger message, the last word being "off".
