Message 21 of 22
Re: Technical help
Thank you everyone for your advice and suggestions. We appreciate your time.
Message 22 of 22
Re: Technical help
Thinking about this further, I don't think any technical solution will help as even if the SSID is hidden, a WiFi signal will be seen and the folks will still attribute it to your house.
