Message 11 of 13
Re: Upload Speed on third party router
I have also tried resetting network connections to no avail. From a google it looks like it could be something to do with DHCP but I really don't understand why it would only effect one PC so don't really want to start messing with that!
Message 12 of 13
I'm having difficulty understanding why it is just a problem with upload and not download. If it was a DHCP/IP addressing issue it would affect download as well as upload.
Message 13 of 13
I have fixed it, it would seem it was a Windows update and is to do with my Killer E2400 Gigabit Ethernet Controller. Although I didn't have any of the killer software installed on my PC I did have the KillerNetworkService.exe service running. I downloaded KillerSoftwareUninstaller which has scanned my PC and done the trick in removing the problems services
Thanks everyone for your assistance!
