Message 21 of 29
Re: Users on FTTP 900, whats the fastest wifi speeds and what router are you using?
If you change the channel width to 80mhz and channel 100. You should be able to get ax on that band. For some reason the 20/40/80 option would only let the devices connect via ac.
Will also stop that 10 mins radar search too.
Message 22 of 29
Only getting ax when 160MHz is enabled may be specific to a particular router.  A little testing with the GT-AX6000 shows it doesn't matter what the channel width ax works!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 23 of 29
Just to update ,
WIth BtHub,  wifi speeds were not good. 150-250Mps down wifi
With New router rt-AX88U Pro.
Iphone 13 -  650Mb    wifi
Macbook  670Mbps wifi
Here is a  speedtest from macbook with a VPN on doesnt even effect itScreenshot 2023-05-06 at 11.40.25.png
Message 24 of 29
If you try https://speedtest.aa.net.uk
seems to be a better Speedtester
Message 25 of 29
seems higher,   but I find some tests more generous in speeds it shows,
730/110 on that.
Message 26 of 29
Yeah seems to be right, you’ll be able to see the speeds on the traffic analyser on the router while doing speed tests
Message 27 of 29
Regards the RT-AX88u Pro:  You can certainly do this with the "Merlin" firmware, but there may be an option in the QOS settings to test the internet speed at the router.
*using the SPDmerlin version of speedtest on the router can negate some issues that would otherwise interfere with a speedtest.
Message 28 of 29
The router built in speed test isn’t accurate tho, can only hit 600mbps
Message 29 of 29
Can't speak for the AX88U, but I can pull 900mbps+ via the built in speedtest on an Asus ET12.
