Message 31 of 34
Re: WIFI Drops all the time
Message 32 of 34
There is no correlation between Ethernet and WiFi.
Devices either connect to your LAN electrically via Ethernet or wirelessly via WiFi protocols.
Think of your LAN in the same way as your house electrical wiring, it is a common network.
Message 33 of 34
thanks so connecting a laptop for instance into the ETH port on the deco will give me internet access
Message 34 of 34
