Message 21 of 32
Re: Websites blocked with following You don't have permission to access "http://www.argos.co.uk
Thank you. Same result.
Message 22 of 32
If you have change the DNS settings on a Windows PC, then you will need to implement the change by opening a command prompt and then input ipconfig /flushdns  then press enter.
Message 23 of 32
I flushed the DNS. It's still the same.
How would this effect the other devices?
Message 24 of 32
I have no idea what the issue is, but it must be related to your account settings.
I will ask a moderator to assist.
Message 25 of 32
Hi @Gill7,
I've been looking into this to see if it's a platform issue at our side but it isn't.
As that's the case, it's most likely a local issue either at your end or else there could be a fault.
I'll need to message you so we can pick this up and help you.
Thank you
DanielS
Message 26 of 32
Hello, I contacted BT again through the website and got some tech support. They asked me to unplug everything from the wired ports, they reset the router and the connection. This has fixed my problem connecting to websites. Thank you for the help.
Message 27 of 32
The problem has now returned yesterday.  I will unplug everything and reset the router to see if this helps.
Message 28 of 32
Do I need to start a new thread?
Message 29 of 32
No, stay with this thread. If you marked it as solved, you can unmark it.
Message 30 of 32
I have unplugged everything and restarted the router through the hub manager. This didn't work so I turned the router off and left it for 5 minutes. This hasn't fixed it. I have called BT.
