Message 1 of 8
Wi-Fi extension
Hi. I need an additional extender disc to bring my Wi-Fi into my lounge which is remote from the hub & existing extender disc. I want to plug an existing network cable from this into my Tv connected P C. How can I justify / order an additional disc?. I have home hub 2.
Thank you
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Wi-Fi extension
Easy
Get one from Ebay
Literally dozens most brand new and sealed from £20
The beauty of the SH2 discs is they work perfectly subscription free and are simplicity itself to set up.
Message 3 of 8
Re: Wi-Fi extension
Is your existing extender disc a BT Wholehome white disc, or a black one that integrates with the hub's WiFi?
Message 4 of 8
Re: Wi-Fi extension
Hi. A black one which came with the hub2. It extends the signal well, but I need to get close to a patch lead in the lounge to plug my pc into it. It’s too far for a single disc extension. The walls are very thick.
I ordered a second hand one from eBay this evening. I couldn’t see any way to request or buy one from but.
murray
Message 5 of 8
Re: Wi-Fi extension
You can request one from BT customer services
0330 1234 150
Message 6 of 8
Re: Wi-Fi extension
Buying one is probably the best move.
Message 7 of 8
Re: Wi-Fi extension
With the black discs, my understanding is that you pay for the service and up to ~3 discs for the same price, you just need to request them. I remember I did this (a few years ago) in the MyBT App on my mobile in the Help chat.
Anonymous
Not applicable
Message 8 of 8
Re: Wi-Fi extension
So the moral of the story is come renewal time just buy a bog standard broadband package from BT and supply your own discs...simples
