Message 11 of 38
Re: Wi-Fi not connecting to TV
Comment deleted - already commented on by other posters
Message 12 of 38
I mean QR code
Message 13 of 38
The QR code isn't the wifi password, no idea how you managed to connect other devices with it. Are you sure youy are entering the wifi password manually and not the admin password.
Are you sure its your hub that the TV is seeing and not a neighbour's?
Message 14 of 38
I don’t know if I can post the image here. On the router, there is a QR code on top, followed by network name and then network password.
When I connected my mobile phone, I scanned QR code with my camera and it automatically picked the network and password.
When I try connecting my TV I search for wireless network, select the right one and then enter password manually. But it doesn’t connect, I get the error message saying,
“automatic IP setup failed. Try the following to set up an IP address automatically. Or, set up an IP address manually by selecting IP settings.
-Make sure the DHCP server is enabled on your wireless router and turn it off and on.
-Contact your internet provider for more information. “
I have checked and rechecked, and network/password is correct.
Message 15 of 38
You can use the camera icon to post a picture if you are using the desktop version of the forum, but it is not available on the mobile version.
I assume the router is not a BT hub.
Your last post seems to indicate the TV is connecting to the wifi but not getting an IP address for some reason.
Make sure your TV is set to obtain an IP address automatically or alternatively enter an IP address manually.
For a BT hub, use 192.168.1.10 Gateway 192.168.1.254 Subnet mask 255.255.255.0 if its a third party router it might be different. If you post the IP address of any device connected, we can advise the settings.
Message 16 of 38
192.168.1.86
this is the IP address for my phone. I’m going to login to a laptop to post image
Message 17 of 38
Ok, so the settings I posted should work but if not try 192.168.1.1 as the gateway.
Message 18 of 38
What would be DNS server?
Message 19 of 38
8.8.8.8 and 8.8.4.4
Message 20 of 38
It did not work.
IMG_7301.jpegIMG_7304.jpegIMG_7305.jpegIMG_7306.jpegIMG_7307.jpegIMG_7308.jpegIMG_7309.jpegIMG_7310.jpeg
This is what i meant when i was using QR code.
This is the router
This is what i get on my TV, it picks up the network but just doesn't connect.
This is the password i am adding.
This is the error message i get.
I have added the details you shared with me but now i am getting following message.
