Message 41 of 54
Re: Wi-Fi on halo 3 do not pass 145 download
In which way will it harm you to try it? at least it will eliminate one possibility
Message 42 of 54
Just tried again with Wi-Fi off. Same speed of 148.89
Message 43 of 54
Ok will try after 12 tonight.
thanks
Message 44 of 54
Are you using a filter or a filtered socket?
Message 45 of 54
This is bizarre.
Message 46 of 54
I think it is a filtered socket
Message 47 of 54
You think? Post a photo if you're not sure
Message 48 of 54
Message 49 of 54
@Les-Gibson  I think you are barking up the wrong tree, the OP has a good sync speed to the hub, it is download speed that is the problem. It is more than likely simply congestion, or possibly a faulty hub.
Message 50 of 54
Ok let us consider these 2 portions:
faulty hub: replacing should sort out the problem
congestion: is there any solution to this?
