Message 31 of 54
Re: Wi-Fi on halo 3 do not pass 145 download
Now test your speed again
Message 32 of 54
Same 143 download
Message 33 of 54
Did you try it at a quiet time, between midnight and 6 AM?
Message 34 of 54
Are you sure your ethernet cable is OK? If you have Wi-Fi enabled on the PC or MAC that you are testing from then turn it off and try again
Message 35 of 54
I tried at 10pm yesterday.
Message 36 of 54
Do you think changing the hub for something else not from bt will make any difference?
Message 37 of 54
Not if your ethernet cable is faulty no.
The reason for asking you to turn Wi-Fi off in post 34 is that I suspect that your ethernet cable is faulty and your connection to the hub is Wi-Fi, turning Wi-Fi off on your machine will prove or disprove that theory
Message 38 of 54
I tried 2 different brand new Ethernet cables. It cannot be that
Message 39 of 54
10PM is peak time, you need to test at a quiet time to discount a problem with congestion.
Message 40 of 54
Third party G.Fast modem/routers are very rare.
