Message 11 of 19
Re: WiFi 6 Modem/Router
That's what I thought - thanks for confirming - but I simply can't get the router to generate an Internet connection. Using the app on my phone to set the router up starts the process and connects directly to the WiFi generated by the router, but it then fails. Very frustrating. I assume you just connect the modem to the WAN port on the router? Do you have any other ideas? Thanks for your help so far.
Message 12 of 19
Just connect the ONT to the WAN port on the Asus and configure it as a PPPoE connection with username [email protected] and password BT
Message 13 of 19
Thanks again, but how do I configure it at all when it's not recognised?
Message 14 of 19
You configure the router with those settings. No idea what you mean by it's not recognised
Message 15 of 19
Sorry for the ignorance. How do you access the router settings to configure it?
Message 16 of 19
Here's an idea, try the user manual
Message 17 of 19
OK - thanks for your help.
Message 18 of 19
Personally I just installed a PPoE WiFi6 access point and disabled the WiFi on the SH2 thankfully a good Black Friday deal came up.
Message 19 of 19
I'd just like to say thanks once again. I've now managed to connect the router to the Internet after your advice. Much appreciated.
