Message 1 of 2
Wifi issue with Laptop Windows 11
I have issues with the internet speed , in mobiles android as well as ios the internet speed is 70mb/s for download and 30mb/s for upload but in laptop its 1 mb/s for download .Please suggest how to fix it . I have restarted my wifi adapter ,other wifi’s are working with my laptop.
1 REPLY 1
Message 2 of 2
Re: Wifi issue with Laptop Windows 11
Hi @Dhana,
Thank you for posting. I'm sorry if you're experiencing issues with the wifi speed on your laptop.
There are a few things you can try like factory resetting the Hub to see if that helps. You could also try changing the wireless channel.
Thanks,
Paddy
