Message 1 of 13
Wired networknotworking
Got full fibre a few months ago
not really impressed no different to broadband before really
none of the wired networks I have work now I have two 8 port hubs one upstairs and other downstairs to connect devices around home but doesn’t recognise any
any ideas what’s wrong
12 REPLIES 12
Message 2 of 13
Re: Wired networknotworking
Can you draw a diagram of the network topology please?
Assuming you are using switches when you say 8 ports hubs?
As for 'no different to broadband before really' what package did you go for?
Message 3 of 13
Maybe worth powering down both the router and the hubs, then power back the hub and then after about 5 minutes power the hubs back up.
Just to make sure all have re-acquired an IP address correctly.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 13
I’ll try that I have some ring devices and smart sockets and there can be dodgy when you switch router off some re connect  some don’t
It took me ages getting some of smart switches connected
Message 5 of 13
It won’t let me email a photo
it’s basically a lead from router to a hub/splitter then off that to my devices
I have two lots of these
one cable is direct to a ps4 and it doesn’t find it
i was on top grade fibre for a month but I think it’s on lowest package now but I still thought it would be better than fibre to cabinet broadband
Message 6 of 13
Did you get a new SH2 or still same hub as before?  Assuming you mean switches not hubs have you tried turning off the 5ghz network in hub manager and see if that helps your devices connect to the 2.4ghz network. Assuming they now connect then turn the 5ghz network back on
I would also try factory reset by pressing recessed button on back and holding for 20/30 secs until hub lights flash and see if that helps your wired connections. Remember to turn on FTTP in hub manager after deset
Message 7 of 13
I would check it’s not an ip conflict. Possibly the second router is running a different subnet to the first and one of your hardwired devices has a static ip address set.
Message 8 of 13
Only got one router sh2
Message 9 of 13
It’s the sh2
i did try turning 5gh off but that didn’t work
I will try a full reset when I have time in next few days
thanks
Message 10 of 13
Tried switching hub off and disconnected for 15mins
no better
i tried direct connecting a lead to ps4 it won’t conect
it does show up on router as connected to games console but not connecting on ps4
