Message 1 of 3
TP Link
I have a TL-WA850RE range extender which I have connected to my BT smart hub via an Ethernet cable.I have managed to set this up and have about 5 or 6 separate devices connected to it which all work fine.The only thing that doesn’t is my iPhone which is IOS 16.1.2 when I connect the phone to my TP link I get a “Weak Security” signal on the WiFi.I have checked the settings in my BT Smart Hub and they are set to WPA2 which is the recommended setting.The only other choice I have is WPA-Auto or None. Any ideas on how I prevent this “Weak Security” signal.Thanks for your assistance.
2 REPLIES 2
Message 2 of 3
Re: TP Link
The TP link device has an in-built web server for setup purposes, I suspect that you will find that encryption is set to WEP, it needs to be WPA2.
The setup manual gives two methods of connecting to the web server.
Message 3 of 3
Re: TP Link
I suspect it is probably just the usual Apple paranoia and can be ignored
