Message 1 of 5
Discs
Is there any setting that can tell my PC to connect to the main hub rather than the disc please?
Thanks.
4 REPLIES 4
Message 2 of 5
Re: Discs
Usually the PC will connect to the strongest signal so why would you want it to connect to what is potentially a weaker signal. If your PC is located such that it gets an equally strong signal from both your hub and the disc then you have the disc placement wrong and moving it further from the PC should resolve it.
Message 3 of 5
Re: Discs
As I said, because it is slower through the disc than direct through the router.  The disc servers several client devices so cannot be moved.
Message 4 of 5
Re: Discs
No, you left that little detail out.
Quote: Is there any setting that can tell my PC to connect to the main hub rather than the disc please?"
Message 5 of 5
Re: Discs
Quite right.  What I should have more accurately posted was “As I said to Arti”!
Arti is an excellent listener.
