Message 1 of 72
Help Activating Discovery+ account
Hello!
I'm trying to activate my Discovery+ account through the e-mail received a while back but i get the below message and when clicking though it just takes me to the My BT page with no further details on how to activate.  Am i missing something?
Activate discovery+
To get set up, please head to My BT and follow the simple activation steps.
Code: WB310
71 REPLIES 71
Message 2 of 72
Re: Help Activating Discovery+ account
What BT Sports package do you have?
If you have BT Sport TNT on BT TV, then you activate via www.bt.com/mybt
If you have the standalone TNT app, TNT on Sky, a monthly sports pass or TNT sports free with some BT Mobile plans, then you activate via www.bt.com/sport/activate-discovery-plus/
Message 3 of 72
Hi Richie, Thank you for replying, Its through Sky so its the second link I used but that just takes me to the aforementioned issue.
Message 4 of 72
Have you setup your BT ID and claimed account holder status? to check when you login to www.bt.com/mybt does it show you're the account holder and can you view your bills?
Message 5 of 72
Hello, Yes I have, I'm showing as the account holder and able to see bills.
Message 6 of 72
There's not much more you can do at this stage, you can ring BT and ask for help or possibly the amazing @DarrenDev  could take a look?
Message 7 of 72
Thanks, I'll see if the person you tagged can suggest anything, otherwise I'll call BT tomorrow 🙂
Message 8 of 72
I haven't seen what a MyBT profile looks like for a Sky subscriber, so can't say for sure what your options will be.
After logging into www.bt.com/mybt select "Your products".
You might see an "Activate discovery+" at that point. If not, select the Manage button for TV and Sport (if you see it).
If that fails, feel free to email me at [email protected] and include your BT ID and BT account number in the email. I work with the guys who manage the activation journey, so should be able to find what's going on tomorrow.
Message 9 of 72
Thank you, I wasn't able to find anything that helped in the "Your Products" page so have e-mailed you my details as requested
Kind Regards
Message 10 of 72
I'm having the same problem.
I'm stuck in a hellish loop that asked me to go to MyBT and follow the 'simple instructions' only to get there and find no instructions.
