Message 11 of 14
Re: Unable to access TNT Sport via TV Set Top Box
Hi,
Is it the BT Set top box that you've got ? Mine has the Discovery+ app on it and I'm able to view TNT Sports through that.
Message 12 of 14
Discovery+ isnt shown as an app via the BT Youview option, i have tried to add it, but i cant as its a Sharp TV, as said before, the option seems to be to buy a fire stick and stream that way - will give up with BT as ive got nowhere and trying any channel via the BT set top box just spools currently, must be my set up ... thanks for all the advice..
Anonymous
Not applicable
Message 13 of 14
Did you get any contact as @DarrenDev suggested would happen?
IPC6023 is usually associated with failure of the network to provide the box with the multicast signal it requires. I'd suggest buying a long ethernet cable for a few pounds to replace the adapters, just to eliminate them.
The DIscovery+ app is only available on the Pro Box at the moment. If you have one of those then you could try connecting by WiFi instead of ethernet or adapters.
Message 14 of 14
no nobody contacted, thank you for all the information, im giving up im afraid as the set up we currently have doesnt seem to work with the set top box anymore - thankyou again
