Message 1 of 5
Hello I was given a bt box pro by a family member. Can I still add BT services to it even if I didn’t get the box directly sent from BT via a new subscription?
thanks
4 REPLIES 4
Message 2 of 5
Re: Bt box
I don’t think BT would add any of their services to that box for you. You’d need to take out a new 24 month subscription and BT would loan you a new box for that. You don’t say how the family member came about the BT pro tv box, although I’m aware of their availability from one or two sources.
Message 3 of 5
Re: Bt box
Hi, @FC12 thanks for posting as @Brucemeister5 has mentioned the Pro box is loaned as part of a subscription. If it was provided by BT to your family member and they don't return it when asked they will be charged £115.
Neil
Message 4 of 5
Re: Bt box
Thanks Neil
they took out a new subscription but  still using a old box which they want to keep because of their recordings.
Do they still send the new box back then or only  send it back if they cancel BTTV?
Message 5 of 5
Re: Bt box
Hi @FC12 It will be requested back if they cancel.
Neil
