Message 11 of 32
Re: Windows cannot login with BT TV player
Thanks, I'm running Windows 10 Home version 10.0.18363 with a physical keyboard.
The BT TV player version downloaded yesterday was 2.0.0.0
Cheers
Message 12 of 32
Ok, fault found and fix now being tested. We'll release it later today - I'll post here again when deployed.
Message 13 of 32
The fix has now been deployed. The app may cache the old behaviour for a while - if so then you can follow these instructions to force it to load immediately:
-Open File Explorer
-Select the address bar and paste the following "C:\Users\%userprofile%\AppData\Local\Temp\EBWebView" and press enter
-Delete the contents of the folder
-Relaunch the app
Message 14 of 32
Now I get WM001 error
Message 15 of 32
At what point?
(sorry, I'm not able to check logs to see for myself)
Message 16 of 32
Ok, so deleted folder and reinstalled a second time and all ok now.
thanks
Message 17 of 32
Thanks Darren, i'm now able to log in successfully but get error WP035 whenever trying to start a program.
I've cleared the cache, rebooted, uninstalled and reinstalled the player and tried using Chrome and Edge as the web browser.
I'm not able to find anything on error code WP035 error on the internet or BT help pages. Could you advise further please?
Thanks,
Message 18 of 32
Hmmm.  You're not the only one @xtreme4l - I can see lots of people currently experiencing this same issue.
I've sent a message to the dev lead to find out what's going on - it looks to me like an error at our end.
Message 19 of 32
Could you please try watching a live channel? I can see all your attempts to watch on-demand content, but it would be good to verify whether your device is able to play live too.
Message 20 of 32
Sure, looks like the same issue, I get the cover / title page come up, then errors with WP035.
