Message 1 of 5
BT Fibre 100 / 300 / 900 availability
I live in a fairly small cul-de-sac which has recently had a lot of BT Openreach engineers laying fibre.
The house opposite me (and it's across a small cul-de-sac road and now a 2 lane highway!) is maybe about 15 to 20 metres away - it can get Fibre 100/300/900, but when I use the BT checker I can't get any of these. Various other houses can also get fibre, but this one is closest, so best example.
My question is this, why can't I get these services into my property? Is there anyone / anywhere I can go to get this explained? Many thanks.
4 REPLIES 4
Message 2 of 5
Re: BT Fibre 100 / 300 / 900 availability
You could try the FTTP team. 0800 587 4787
Message 3 of 5
@chriswilding1974
Only Openreach would be able to tell you whether fibre is available.
BT Openreach do not exist, its just Openreach.
Message 4 of 5
Thank you for this advice!
I spoke to the team who advised that I could indeed get these products. They kindly completed a form for Openreach so I hope to be able to order my upgrade in a week or 2.
Message 5 of 5
Good result!
