Message 11 of 14
Re: BT GFAST going slow and intermittent
This is latest Just now.   149 /25 to the hub ...which is below the guaranteed....
Message 12 of 14
The speed to the hub will vary, depending on the number of customers connected.
Your physical connection (sync) speed will remain fairly constant, as that is dependent on the actual line conditions, which should not change very much, unless there is a line fault.
Message 13 of 14
So...looks like there is a big fluctuation ... as you can see its 149/192/182 ..etc etc.. and 24/27...
Shall I report a line fault and ask them to come and investigate ?
Message 14 of 14
@ssrivast12 wrote:
 This is what my package says
As the speed to your hub at the moment is 183mbs, its above the guaranteed minimum speed of 150mbs.
Overall connection speeds are likely to drop, as more customers get connected, and crosstalk is increased. You may have been getting a faster speed before, but that is no longer possible.
