Message 21 of 22
Re: copy and paste password
Hi @Manta_Ray I just wanted to reiterate what has been said before that the TR69 logs on your Hub stats shouldn't be a cause for concern, as that's how BT remotely update and manage the firmware.
Neil
Message 22 of 22
Thanks NeilO, it's not the TR69 logs as you cleared that up for me. I can't give specific info over the net for obvious reasons.
I may need advice on legalities in time. IE tracing and prosecution of the perpetrators.
